James_G
ORIGINAL: DavidL
James that nice ali jack you have. I'm assuming its man enough for the job as I'm sure its only rated to a little over a tonne? It would be a good choice as nothing else I've seen will slide under my Caterham let alone the 944!
My year old Halfords trolley seems to have a an air leak and won't lift anything - PITA for jobs like this.
Again thanks in advance.
David,
Good to hear your progress. Firstly, the ABS clippy things I have just picked up from my local OPC and they were £2.38 each for the bigger ones, and £1.13 for the small ones (or therebaouts). You could not bother and just use tie wraps and/or tape but I like to do these things properly and I was ordering some other bits too.
Meanwhile the jack is very good, and yes it's the only thing that fits under the S2. I do use a Halfords jack as well to lift the car level to get axle stands underneath, but I have to start with the low profile one first. I got mine from Argos Extra and as I recall it was £80, but I think it or something similar is available from Machine Mart. As I said elsewhere, I wouldn't be without it.
James
