Spares Listings
- Thread starter John Sims
poprock
ORIGINAL: Wigeon Incognito
I have a used set of 17" Boxster 'Twist' style wheels with tyres (but no centre caps) for sale if anybody is interested.
I've emailed you about those.
Wigeon Incognito
ORIGINAL: poprock
Maybe give the e-mail another try, it hasn't arrived in my inbox.
Wigeon Incognito
Wigeon Incognito
Matt.
Paul Fraser
Suffolk944
Moderator
Yup - sent a reply let me know if it didnt get through.
pauljmcnulty
elvis
ARBs, 26.8mm front, 16mm rear. £25 for the pair Now on ebay, along with some 24mm torsion bars..
Rear shocks, boge gas type. Some damping left but not great. Free otherwise they'll be binned
Front struts, one damper completely dead but may be useful for koni conversion. £15
Cylinder head. Good condition, no cracks etc, bought used from PH in Shardlow. No cams, tensioner etc, but the cam caps are included. Valves included but missing a valve spring and several of the the spring seat shims. £200
All parts in Nottingham, collection would be best as they're all fairly big and heavy. PM or email me through this site if you need any more info, photos of all the above are available...
Tim
yipadee
have a few things for sale:
- 944 old style dash - sunvisor bracket (long black strip which sunvisors attach to) - £15ono
- 944 old syle dash - sunroof wind deflector one attachment clip damaged which can be replaced - £12ono
- 944 old style dash - 3x wheel nuts - brand new 50p each
I am located in Crawley, west sussex
Photos of all these items are available, please reply to this message or email:danharris1976@tiscali.co.uk
Please note i am attending the cotswold rally on 27th April so could poss deliver then if interested, otherwise collection prefered or can arrange delivery if requested.
Dan
sawood12
944 turbo rear torsion bars. A good upgrade for 944 n/a's. These are the same bars that are fitted to S2's and the early 220bhp turbo's (and 968's I think). It is 23.5mm in dia. I have no idea as to the equivalent spring rate. £80
944 turbo rear shock absorbers (pair). Stock Boge/Sachs non-adjustable shock absorbers as installed on S2's and turbo's. I bought them off ebay but never installed as I went the KW route. They were advertised as being on the previous car for only 6 months. They look OK though there is a crack on one of the plastic shrouds but this shouldn't be an problem regarding the working or operation of the shocker. Apparently these shrouds are prone to cracking. £20.
944 turbo rear shock absorbers (pair). These are the same as the item above but the ones that came off my car when I installed the KW. Perfectly functioning and MOT passable. Obviously they have a fair few miles on them so are probably beyond their best but were working perfectly fine before I removed them. £10.
944 turbo front struts/shocks & springs (pair). These are the non-adjustable stock S2/turbo Boge Sachs front struts. Come complete minus the top mounts (which I am keeping). They were perfectly serviceable before I removed them for my KW upgrade. Had recently passed an MOT with no signs of any leakage or play in the strut stanction. A good upgrade for an N/A 944 or even a good 2nd set for someone to upgrade with Koni adjustable inserts. £100.
Drop me a PM if you are interested in any of the items above and i'll be glad to provide more details/pictures if required. Cheers.
Northern924
For 86' manufactured 944 2.5 lux. Guards red preferred but will consider other colours.
Front bumper
Badge panel
Drivers side headlight
Drivers side foglight
Radiator
Spacers x 4 also required for above car 31mm or thereabouts.
Can collect and pay cash on collection
Rob - 07921 573607.
pauljmcnulty
You should have no problem finding all the bits from any of the usual breakers, or look for a suitable car on e-bay. I'd consider buying a whole car and then selling the bits you don't need to break even!
Try porsche-apart or Douglas Valley, they should have a matching donor car in stock.
