In my opinion the Sport Response Button is nothing more than a gimmick. I've never used it on either of my 718's.
At PEC it was demonstrated on the test car, and I found it a completely pointless feature. A keen driver will already have the car in the optimum gear and turbo boost for any prospective overtaking manoeuvre.
As Philip rightly points out, when overtaking another vehicle you should be concentrating on checking the mirrors and the road ahead. Not fumbling for a button on the steering wheel.
The correct procedure is, use manual shifting in Sport mode, selecting the appropriate gear for the overtake, and if the road is safe, accelerate swiftly past. Easy.
Reading the handbook on the use of the Sport Response Button, it is essentially for use when the car is in Normal "D" mode. Activating the SR button will programme the turbo for a faster spool-up, and deploy the rapid-fire gear shifts normally reserved for Sport Plus for a period of 20 seconds only.
SR does not provide any extra "boost" from that already programmed on the ECU.
In other words it's a complete waste of time in my opinion and has no place on a car such as the 718.
Brian
Brian
