TK2015
I bought my 1989 944 Turbo earlier this year and noticed that it was running a bit rich and misfiring slightly at about 2000 rpm. I looked at the air filter and the HT leads and concluded that they had probably not been changed since the car was new!
A quick trawl of the web brought me to the ProMAX site and after a lengthy conversation with Andy I bought the ignition tune up kit comprising HT leads, distributor cap, rotor arm and spark plugs. I also bought the vacuum kit as some of the vacuum lines had seen better days. I also noticed that the car had been fitted with a stainless exhaust, a Hayward & Scott 3" system I believe although there are no markings on it to indicate the manufacturer.
Before fitting anything new I took the car to my nearest Dyno at the Mini Centre in Sleaford - very friendly - to get a baseline from which I could judge whether any of my modifications were actually making a difference. The original trace is below and as you can see there's definitely a hiccup at about 2000rpm. Peak torque is about 190 lb ft at 5000rpm with peak power of 187bhp arriving at just under 6000rpm. All readings are at the wheels.
