Starting issues
Apologies for not updating sooner.
Been a mad busy week or two.
A huge thanks to everyone for the help.
So I changed the battery. Turned out the battery was fine but the new battery is a better battery and cranks much better now. Whilst the old battery was fine, it has benefitted from the upgrade.
Didn't fix the issues tho. But I did manage some trial and error and it was all to do with temperature. Keeping the car in the garage and it started fine every time. Leaving outside, in the cold icy cans over night, it wouldn't.
Replaced both sensors and actually was really easy via back wheel arch.
Looks like they had been done before so came out so easily and no issues at all fitting up. Didn't change the carrier but did use the old sensors and a glued washer as per the advice to check the gapping etc. With some verniers and feeler gauges managed to confirm everything was set up spot on.
Hasn't been a prob since thank fully.
So all the help has been greatly appreciated and am back on the road again.
Thanks!
