helpful this...nice one.
currently having this prob with mi buds s2...
i borrowed her and she kept cutting out...ten mins later shes alive till...cuts out..
having a prod round and tap of relays used to help it seems, but shes been sat in garage a good while and shes dead as at mo.
new relay on order...will report back..
also removing tank to clean out and changin fuel filter...,pipes corroded..need changing and have had to go to hydraulic place to get new unions etc to sorts so can convert with short section of fuel flexi pipe. i serviced it a year or two back and attemtped to undo but it was not good then, i dont think its been changed in a good long while. Many years it would seem
so tank off, clean out..sort the sender which has a loose return feed pipe form its base...been broken by some rough arse it seems (found the fuel odour then) and the jubilee wasnt even connected...nice!, sort the pipework, clean out tank new filter and connections etc...rebuild, new relay up foront, should be good a for a while then...
its a shame as some stuff on the car has had a fortune spent on it but oithers like simple stuff , air filter and fuel havent been touched in years...
we'll get there!
