A strange occurrence yesterday... I pulled up at a set of traffic lights, lights changed, No drive. No warning signs, no previous slipping, no noises, all gears feel to engage the same, but no drive in any gear. I have now had a look under the back of the car, all drive shafts seem intact, and the one other thing I though could produce these symptoms, the connector between eth torque tube and gearbox appears intact (and both shafts turn together. This last fact is I think the give-away that something is up at the clutch end - the shaft should normally be connected to the engine (via the clutch) and it turns freely. The engine starts ok, so I am assuming the clutch outer is all ok and intact, but now I can hear a slight "shushing" noise with gears engaged, clutch up, and engine running. Has anyone experienced such a sudden failure before without warning? Any other ideas? I am wondering if the hydraulics have somehow "jammed disengaged", but the clutch pedal feels as it normally does. I did find the original wax on the sleeve that joins the torque-tube to gearbox, which would suggest the clutch is unlikely to have been changed ever - it certainly hasn't in the 200k+ miles I have covered, so I guess it has an excuse...
Any comments, ideas, suggestions welcome!
Tref.
Tref.
