Suspension Recommendations '91 Turbo
- Thread starter JSHammond
TTM
Well-known member
However, the KW V3 remain the best compromise I was able to find for the wide variety of roads, often in very poor condition, I sadly have to drive on at times. Trying to imagine carrying some speed on these roads with the Bilstein I am pretty sure many bolts and nuts in the car would break off.
The suppleness of the KW, at the cost of losing some absolute feel, is what makes them enjoyable to me. I have them set relatively soft, yet considering how much suspension travel I get I find the car remarkably controllable at speed, which I think shows where these shocks are remarkable, and where Koni yellows would miserably perform. The Bilstein would probably would not perform at all since they seem to work only as stiff shocks.
Neil Haughey
Absolutely nothing is more important than getting the setup and corner weights nailed. Nothing.
MartinRS2K
Then the car was set up and corner weighted and the difference was amazing [
As stated earlier in this thread I had settled on the V3's as I know they really do offer the best of both worlds, but I'm finding it hard to stomach the cost of £1500-1600 they currently cost even when considering a favourable Euro rate at the moment. I could stretch to them, but I am considering a slightly left field custom set up at less than half the cost without the potential drawbacks of the similarly priced Spax and Gaz coilover kits...
https://944tech.wordpress.com/2014/02/12/how-to-a-proper-budget-944-rear-coilover/
Due to the exchange rate a set of Bilstein B6 dampers can be bought for around £380 delivered from Germany at the moment, add in a set of coilover sleeves and my own choice of spring rates and I reckon I can build up a full set of Bilstein damped coilovers for less than £700. The fabrication/engineering side of this is not an issue for me and I have everything I need at my disposal. I already have a set of knackered front M474 Koni's and a set of mk2 golf strut casings to chop up to make the fronts. Overall it wouldn't take much work to do and should be a nice set up; sure it won't be quite as good as the KW's but I reckon it should be 90% of the way there...
I'm thinking of either a Fr 300lb / R 250lb or Fr 250lb / 200lb spring rate set up (retaining the rear bars of course).
Anyone on here running the Bilstein B6 dampers? If so how do you find them? My research suggests they should be more than capable at damping the spring rates I mention above...
Or should I stop being such a tight ass and just get out my credit card!?...
edh
I think someone in the uk is doing the machining to fit bilsteins into front struts now - martinrs2k?
Not driven a 944 with bilsteins but I don't think you can go wrong with them
edh
FWIW, KW v3 springs are 60Nm F, 50NM rear - approx. 342/285 Lb I think and they are fine on the road, so your 300/250 is not far off
I'm now running 500/400 and I'd say they are a bit too stiff for a road car.
I'm pretty keen to give this a go as it may well prove to be a cost effective way to get a decent set up, something us 944 owners are presently lacking given the price increases to the V3's!
Springs are reasonably cheap so I can always play around with rates...
Monkeythree
Richard
ORIGINAL: Richair
So after MUCH deliberation and research I've decided to press on with the Bilstein's. A set of B6's have been ordered from the fartherland for a very reasonable £355 (approx) due to the strong pound. I'm currently sourcing all the other bits, but I hope to have this lot assembled in time for a ring trip at the end of May!.. I'll report back in a new thread once I've made some progress...
Richard
Do you mind telling me where from? I am currently thinking of doing something similar.
Many thanks.
