edh
OK - time for an update
On Saturday I had the car on stands & removed the undertray. Rack was bolted tightly to the crossmember, ARB bushes looked fine, ARB mounts both the right way round, no apparent play anywhere. Springs & helpers looked OK. I was underneath when the wheels were turned & there was no noise. Found one of the crossmember bolts needed a slight bit extra to torque up to spec.
I dropped it onto wooden blocks, again, no noise when turning.
Drive to & from Rutland on Sunday was fine - there's no noise when moving
It just seems to be when the car is v slow or stationary, & maybe the tyre can't slip so easily so the forces react elsewhere. With the window open it sounds like it might be the o/s strut / springs. I'm going to take that strut off the car as it needs the camber adjuster welding up (occasional KW problem it seems) so will have another look when that's off.
Doesn't appear to be a critical issue though.
