My 924 turbo is just coming up to 80,000 miles and is (according to our resident 928 gt driver) still properly quick. It doesn't need a rebore but the cam belt did go and one valve dinged a piston. My cam was bought back in 1992 from a now defunct company called P.M.C. Going from +0 to plus 0.5 in one go is not an issue, it just reduces the number of rebores by one. By the time the engine is ready to be rebored again I wont be bothered about it as I will be the other side of the grass. You ought to gain some mid range torque with the piper cam feartured about a year ago in one of the mags, but, as I have said, do not expect the same incremental chages by re-camming a turbo charged engine. Then there is the questoin of overdoing it and creating a recipe for pinking. I am ok down here, I can, for the moment at least, continue to run my 924 on leaded petrol which despite its 99 octane rating is infinitely superior to leading brands of 99 octane unleaded in terms of knock resitance.
The 924 turbo is never going to pull hard from low down because of the nature of the turbocharger, the engine is always going to be sucking past the compressor vanes below say 2,500 because the turbine has not got a sufficient supply of hot exhaust gas to get it spooled up, so there is always going to be a point at which the compressor starts to move a greater volume of air than the engine can suck, which is of course the point where we say the engine goes on boost. Without the boost you are effectively driving a two litre normally aspirated engine with a c.r.of 7.5 :1 in the case of the 170 horsepower engine. It is not going to be that flexible.
An idea for me is to try to obtain a series one turbo and wastegate and increase my boost pressure to 0.7 bar from 0.64, an increase of about 0.8 psi, but that again may necessitate the intercooler to prevent pinking. When you boil it all down you would probably spend less, wedging a 3.0 litre S2 into a 924s. 2 more brake than a carerra GT. Now that would be flexible. Hmmmmm, now where did I put my shoehorn?
