Update 4 Its been a while since I last updated so thought I'd let you all know how I've been getting on. Alot of the time since I last updates has been spent designing and waiting for parts to be machined. One of the parts Ive had made for the car is the turbo adapter. This makes the transition from the original turbo mount to the oil drain on the EFR 7064. It is a two part adapter made from stainless and Ali. All the structural strength in the adapter is in the stainless.
I also had a boss made up for the original water temperature switch in the turbo water line. This is also made from stainless.
I have also had the hanger brackets for the exhaust laser cut and they have turned out very nicely.
While waiting for these parts to be made I got some heat wrap for my headers and also put in some ports for testing back pressure. These are in headers 1 and 3.
So once I had the parts gathered up I got stuck into my exhaust. The complete system is back purged and surprisingly light weight I haven't weighed it yet but I'd say lighter than OEM.
I am now doing the finishing touches to my x-over before welding it up. This will be completed this week. Once this is done I have an AOS can to make and a couple of heat shields and I can start to make noise. I intend to do some experimenting with the mapping on this car to see what improvements are in it for turbo response. I intend to try lean spool and also some mild anti-lag type mapping in the higher rev range to keep the turbo spinning during gear changes, the ECU fuel cut will protect the turbo and exhaust from getting too hot.
