The story so far.
- Thread starter Guest
ORIGINAL: Diver944
Slim, according to a 1988 test in Motor magazine the time for 60-100 was 8.1 seconds, but it didnt say which gear. Has to be 3rd as 2nd runs out at about 70 and 3rd at about 120 (I think [&:])
Great so i have knocked about 2.5sec off the 60-100
Prob about 1/2sec off the 0-60 (guess)
So looking at a 0-100 time of around 10.7sec
Thats pretty quick aint it?
Diver944
Your projected figures are now nearly identical to a 968 Turbo S as tested by Christophorous magazine in 1993 0-100 in 5.7 and 60-100 in 5.7 which went on to a top speed of 174mph from a 305bhp 3 litre engine
All projected figures of course [
That gaugepod looks pretty good Tony. How did it fit? screws or double sided tape?
I used longer screws into the original holes for retaining the trim, I painted the heads black and they look OK. I had to drill the pod at the right points.
Unfortunately I also used a P-clip with a short bolt to retain the wires - where I positioned this damaged the trim behind the pod, so I didn't manage to quite get away without marking the trim. Never mind I think the pod is here to stay anyway [
I also had a gap by the windscreen, I cut a section of old sunroof trim to finish off this area.
The gauge pod is finished in a kind of shiny leather grain - it doesn't match but its not too bad - many are finished in 'carbon look' [:'(]
Tony
(universal 2 pod from Regal in Southampton as I was passing them yesterday).
Do you have a web site for them, Tony?
John,
http://www.regal-shop.co.uk/ search for gauge pod - its a universal pod so you have to cut it to fit ( and then it is not perfect hence the extra trim ) Its not bad though even with my lack of manual skills.
I found there are many others on the web but it is very hard to distinguish between them - and in fact many may well be the same [
Tony
Tony
John,
Thanks Tony.
Does look very similar to offerings in Demon Tweeks.
The paperwork that arrived with the chips does mention 15-18PSI.
Interestingly driving today my car (pre guru) seems to run rich on Boost (also yesterday Jim mentioned black smoke from the rear and it is particularly sooty at the moment around the tail pipe. I did ask Janspeed to ensure it didn't run lean when they had it on the rollers for exhaust tests, but dont know if they adjusted it.
Tony
Yes I will have a go at leaning it out a bit - at full throttle / boost should we be aiming for
a)slightly rich
b) the high side of stoichiometric
or
c) the centre of stoichiometric ?
What you getting slim?
