Tial DPW
- Thread starter mike220
Anyway got it on this morning and the difference is amazing, the car comes on song so much faster and holds all the way to the red line. To be honest I had a bit of a moment coming off a roundabout as I wasn't expected the car to boost so soon. All 944's should have this done.
But I do have one question, on the instructions that came with the DPW it shows the top vac hose venting to atmosphere and the side vac hose connected to the banjo bolt via the MBC. If you look at the Lindsey racing web site it shows the MBC in a loop between the top and side vac hose. This seems a better way, just wonder how you guys have yours plumed in"¦.
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=MBC-DUALPORT
Jobs for tomorrow is fit my 3bar fuel reg and also my high fuel chips.
Diver944
TTM
Well-known member
It is - I cannot understand it myself.ORIGINAL: Fen That's weird.
Same here. In my case I believe it even slightly increased lag, and the reason might be I fitted way too long piping between the MBC and the wastegate.ORIGINAL: Diver944 However when I did this with an MBC it made little real difference.
sawood12
sawood12
sawood12
Suffolk944
Moderator
