chrisg
In answer to your question, no you don't actually need the timing belt tensioner tool to set the tension. However if you've never done it before you'll have no reference point on how tight it should be.
On a separate note you WILL need a flywheel lock and a deep 24mm socket to get the crank pulley off.
Whilst ur doing the cam belt you should also do the balance belt and pas n alternators too.
Happy to talk it through with you on the phone - I also have all the relevant tools you'll need.....
Chris 07540193874
Chris 07540193874
