Dan944t
Hi Phil ,
last set of belts and rollers that I bought and fitted to my 87 turbo was I believe continentals ( they were bought from Andy at Promax )
In all honesty I havnt converted from manual tensioner to spring loaded, but I have got the experience of both as I also have a non turbo 944 1986 lux which has the adjustab tensioner, and have done the belts on both a couple of times, and all I can say is I much prefere the spring loaded self tensioner as I have had a belt snap on the non turbo when I was 18 and it's always plagued me since, and so when I first did the belts on my turbo I a good feeling of reassurance in knowing the spring was giving the tension ( although you always need to check for tension after maybe 500 miles I think it is just to be sure things don't loosen up )
be sure to change all the rollers whilst doing your belts as one of my rolkers was the cause of my belt snapping where it wasn't spinning anymore where it dried up from the heat of the engine.
You live and learn as they say That cost me thousands believe it or not!
all the best
Daniel
all the best
Daniel
