Timing Belts
- Thread starter Dan944t
Indi9xx
Very flimsy plastic bit, the often people throw away thinking it doesn't do anything.
944.602.803.00 from Porsche main dealers, about £10 plus VAT retail (Used to be about £2.50!) They list it as a "Dust Cap" but it's main job is to separate the electrically charged ionised air from inside the distributor cap, from the free flowing air within the belt cover. It is not air tight, but it limits the amount of airflow between the two.
Also known as an Ozone cap, searches for the effects of ozone on rubber via google should bring up pictures of the familiar cracking you see on old tyre sidewalls. Ozone is a byproduct of electrically charging air molecules.
It is not only rubber, but also other materials, such as aluminium or as a rule, anything which suffers from oxidisation or degradation in an oxygen environment tend to suffer entropy being accelerated.
Interesting is the effects of ozone on combustion, which has been found to reduce the delay between ignition and combustion. So in theory, a vacuum hose routed to a hole in the distributor cap, routed to the intake manifold, could in theory reduce oxidisation of the rotor arm tip and contacts within the distributor, as well as potentially improving performance or efficiency... However, scientific tests have found the performance increases are not measurable, even though the combustion delay reduction has been observed.
Chemistry and Physics at play.. If more performance tuners studied and showed an interest Chemistry, Physics and certainly thermodynamics, more power would result..
vitesse
As all the distributor does on a 924S/944/968 is distribute the spark to each plug in firing order,I would image the benefit of such a shield is not measureable.
Indi9xx
vitesse said:Well neither of our 924S's have them-but our original 924 Lux had one to cover the Hall effect sensor & shield it from ill effects.
The original question that spawned the explanation was what outside influences degrade the belts. Ozone created within the distributor cap is far more corrosive than oxygen, which is far more corrosive than the air around us, especially for rubber components.
Spark performance will indeed not change if the car has or has no ionisation/ozone cap.
Indi9xx
Does not need to be air tight, just to stop it being open to the belt cover, or at least have more square mm of ventilation in the cover than it has between the cover and the distributor cap, if that makes sense.
Indi9xx
You could all decide that as your cars do not cover many miles per year that you could stretch out belt changes to 10 years, ditch the ionisation cap and all sorts of things like that, but that's cutting corners I would not want to cut.
vitesse
I'm well aware of the ozone problem with belts but why would Porsche miss it off on our grey car where we are only the 2nd owners & can't see why it would have gone missing at 26K miles having been serviced by a main dealer,the original supplier.
As ozone is present everywhere,there is a continual air change in the engine compartment /distributor cap-differential pressures everywhere,it's effect can only be marginal for the average owner,who listens to forum posts & abides by the advice.
