JamesO
Just fitted Microsquirt as per a thread on rennlist (pre built megasquirt 2 in a small case). After a bit of messing around I have the car running and driving which is good.
I had to add an inlet temp sensor, I was hoping to use the one in the AFM, but it wouldn't work, all other sensors are as stock with the exception of the wideband o2 sensor to help tune the thing. Oh, and a manifold pressure sensor.
Cant play too much as my laptop is playing up which is annoying.
I have the North American timing map, does anybody know where I might find the European maps or if they are much different? I know they have a lower compression ratio on their 944 lux's
