Timing map
- Thread starter JamesO
sawood12
extract from 'evil 944T' on page 11:-
It can be triggered by many different triggers. The stock triggers on the flywheel can be used. If so, a special trigger board needs to be fitted, (no charge) at time of supply. All of the other trigger options are digital and can be selected in the software.
A 24-1 wheel that can be attached to the stock Cam wheel and the Hall sensor fitted in the Cover. This allows sequential control. The stock sensors without a cam sync can only be group fuelled.
The Ignition will be sequential if the Distributor is used. Wasted spark can be run off the stock sensors. With the 24-1 cam wheel, 4 individual Coils can be used sequentially.
I think the stock sensors with either wasted spark or stock Ignition is OK. The only issue is the sensor could fail.
The Cam trigger is far better and will not have any temperature issues.
The thread is called 'Standalone EMS...?' (can't seem to link direct to the thread: http://forums.rennlist.com/)
Hope it makes sense to you and it is useful.
