Took the plunge
- Thread starter texpis
pauljmcnulty
texpis
It does have a service history the last service was late 07 just befor it was taken off the road. It was seviced by Cridfords of surry I will ring them tomorow yo see what was done. I may change them anyway for peace of mind. What is the deal with the waterpump if it fails does it take the timing belt with it?
Mick
Suffolk944
Moderator
ChasR
ORIGINAL: texpis
Cheers paul
Mick
Hi,
It does indeed take the belt with it if it fails. If you are unsure of how to go about it, take it to a specialist. Whereabouts in the country are you?
Either way, it's a lovely looking S2 Cab.
pauljmcnulty
Cheers for the replies, I am going to do my own work on the car I like working on cars as mich as I like driving them. I have read that every second cambelt change to change the water pump is this because a siezed pump will take out the cam belt?
It's recommended, but also because most cars are on the original unless recently changed. Same as the cam chain and slipper on 16V engines. I'd also do oil seals and rollers whilst you're at it, then sit back and do belts every 4 years/40K miles knowing you've covered the other problems that might come up. My Lux was effectively stored for 18 months and it needed the oil seals changing, and a new belt replacing again as it was covered in oil. [:'(]
sawood12
robwright
ChasR
One local specialist said to me not to even change the tensioners until they start making noises etc. as 'if it ain't broke don't fix it'. They did recommend for me to change the slipper pads and chain mind you. Another said to change the tensioners at every belt change reckoning that they let go before anything else. Both thought changing the pump was not quite necessary.
I reckon the quality of the antifreeze and proportion of it affects pump life. Or at least my Mondeo's one was fine via that theory (ran on nothing but Ford's 10 year antifreeze (was changed 2 to 3 times in the car's life)) and at 390k, the engine was still on the original waterpump.
Suffolk944
Moderator
ORIGINAL: robwright
John in your signature after you said when it finally arrives from across the pond you forgot to add and I get massively bummed for import tax []
Yup, you've got to love the tax man ! [&o][
Still waiting too...
Belts and waterpumps. Certainly do the belts. Have a look at the cam chain and slippers/tensioners, as these can lead to an expensive cam replacement if neglected. Water pump? There have been various discussions on here about replacing them, and I think I'm probably with the 'garage profiteering' mindset.
Diver944
ORIGINAL: Suffolk944
Yup, you've got to love the tax man ! [&o][]
New thread for full details please [
What did you plump for, did you get the V-Flex too? [8D]
The alternative is to leave it and risk joining 944cop with a top end rebuild when it fails...
Yes ... I saw that thread as well. [ORIGINAL: graham.webb
Good point.
texpis
Mick
texpis
http://cgi.ebay.com/ebaymotors/New-PORSCHE-944-944S2-S2-WATER-PUMP-Gasket-89-90-91_W0QQcmdZViewItemQQhashZitem1c0b4573d7QQitemZ120448185303QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
