Steve Brookes
Moderator
ORIGINAL: Gordon Attar
Either Ray Northway himself or more likely Paul (90%) will be doing the rebuild. You need to trust them as they only advise on rebuilds if they are neccessary, they will advise you what needs doing and they are honest about there assessments, more often than not they only do the top end. You need to check what is in the top end rebuild and whats not, a lot of people are surprised by whats in in Northways £3.5k rebuilds compared to some of the competitors, so it would be good to double check and post the answer.
From what I can see on this thread no one has questioned Ray's price or integrity. The base price of my own top and bottom rebuild was very similar to Ray's price. It included new valve guides, dialever head studs, cam chains and guides, piston rings, oil through pipes, main bearings, all seals and gaskets, reconditioning the heads and of course, oil and labour.
What it didn't include was new parts that were found to be worn out or damaged which for me were; camshafts, valve springs, top hats and retainers, little end bearings, split engine cowling, warped lower valve covers, crumbling heater hoses, corroded cat converter flange and various oil and breather pipes. It also didn't include stuff that I knew would need doing at some point but had been putting off (starter motor, clutch slave and hose some new tinware). It's the extras that take the rebuild to another level.
If none of these extras had needed doing I would have paid a very similar amount to the Northway rate. One could almost argue that if it's only the top end menu items that are found wanting when it's opened up.....it didn't need a rebuild in the first place.
