Top Gear Exhaust?
- Thread starter millimeep
ORIGINAL: millimeep
Chatting to John at Tower Porsche, he said that Dansk are OEM suppliers to Porsche, so it's a stainless version of the OEM mild steel one...
The OEM mild steel one was stainless
Tony
(Thanks for the update on Pete Paul)
ORIGINAL: nick3814
Fen, I wouldn't say this is "customising" the exhaust system! It will look nicer and perhaps sound a little nicer, I'm not into some loud boy racer spec system, I like it to look original but a little special and I think the one thing that lets down all original 944's is their sound, the exhaust note is a little bland don't you think?
I meant the Top Gear or Longlife style, not an aftermarket one that has (hopefully at least) had a bit more knowledge used at the design stage.
berg944
Here's a couple that I took when I installed it: (Aug 2004 according to the date of picture). I can't see any seam that you might be referring to, let me know if you need a different angle
Cheers Paul, I think I will try one.
Do you still have a front box installed?
Mike
Diver944
ORIGINAL: berg944
No, the front box was cut out and replaced with a straight pipe a couple of years ago just after the rebuild. It's still pretty quiet compared to most aftermarket exhaust systems
