This may be a useful resource for assessing inner and outer clearance and diameter effects of changing wheels and/or tyres.
http://rennlist.com/forums/tire_rim_calculator.php
I guess you are currently on 20" 8.5" front wheels running 235/35 tyres. I have moved from this to same size front wheels and 245/35 tyres with no issues from the electronics. Even with the standard 235/265 front/rear tyres I had understeer. I skipped experimenting with 245/265 and went to 245/295: I was able to tune out the extra understeer from the increased front/rear tyre width difference with more front camber using Powerflex camber bushing on the front and maybe extra grunt from the engine.
I tried 245/285 as part of my understeer management process but am reverting to 245/295 as the 285 on an 11" rim is too narrow to allow the tyres' rim protection to protect (as I recently found out).
I now run two set of wheels, one with Cup2s and one with MPSS.
Re Michelin and N rating, it would be good if they introduce a homologated MPS4S for Porsche but based on the frequent "it'll be soon" stories for 997 and 991, I would not hold your breath. But as long as you choose the non-Merc/BMW/Ferrari versions they will be good I am sure, but not N rated.
Re your Porsche Centre, it is nonsensical that they will not raise warranty as an issue if you fit a non-standard tyre type with non-standard width so long as it is N rated for another Porsche model.
I'd bite the bullet, get another set of wheels and fit the tyres you want and save the standard items for visits for warranty/service work at the Porsche Centre.
