ORIGINAL: sawood12
			ORIGINAL: jamescharnley
 Is the earlier 220bhp turbo much different from the 250bhp?
 Engine -  The 220bhp cars are fitted with a K26/6 turbo and the 250bhp cars have a K26/8 the difference being the size of the compressor which allows the 250bhp cars to maintian the max boost level to the red line where as the 220bhp cars' turbos' will deliver max boost at around 3500rpm and it will start to bleed off boost gradually to a lower level as the revs rise to the red line.  Other than that the engines are basically identical apart from later additions due to the fittment of Catalytic converters and other things useless things.
 Suspension and Brakes - M030 lowered and adjustable Koni suspension, stiffer ARB's and the larger front brakes carried over from the 928S4 were fitted.  Not sure if M030 was std on all 250 turbos but it certainly was on the later cars.  The 220bhp cars did have uprated suspension over the lux's and S cars and it was carried over to the S2.
 Gearbox - Although the ratios are the same the 1st and 2nd gears are hardened, the driveshafts are toughened, an oil cooler is fitted (only really required if you are tracking the car alot) and an LSD.
 0-60 times - 5.9 secs for the 220bhp cars and 5.6 secs for the 250bhp cars (depending upon where you read the figures from)
 M030 and the uprated gearbox were optional extras on the 220bhp cars so you might be lucky and find one that's been specc'd up.  Other than that they are the same car.  I got a 220bhp car purely because I bought the car on condition.  If you are going to modify the car you can easily get a 220bhp car upto around 280 ish bhp with the K26/6 turbo and if you were to simply replace the turbo you'd be good for inexcess of 300bhp safely and without too much trouble.  Obviously the key to your decision is how much do you want the M030 and the uprated gearbox.  For regular track work you definately want it.  For primarily road work with the odd track day M030 might be a bit uncomfortable and the lower ride height might cause you a few scrapes. Uprated brakes are always a good idea on any car if only for the looks!!!
 I've never driven a 250bhp car but i'd be surpirsed if you could tell a great difference in performance on the road under 'normal' driving conditions.  On the track though i'm sure the extra 30bhp and associated torque would be noticable and useful.
 Don't go away thinking a 220bhp car is a slouch.  Mine currently is practically standard apart from the addition of a dual port wastegate, Janspeed exhaust and a tweak of the max boost level from stock 0.75 bar to 0.8 bar and I got 237.5bhp on the rollers of truth at Weltmiester.  In reality the car is scarrily fast and you get a good strong kick in the back when the boost cuts in.  It definately has noticably more umph than my mates 222bhp Leon Cupra R and my other mates Civic Type R - and it even feels more than a match for a work collegues 993C2 (difficult to tell due to the smoother power delivery of the 993) and normal Boxters feel pedestrian in comparison.  Max speed i've done is 120mph but it would still accellarate strongly at that speed so I am in no doubt that the top speed of 157mph is achievable.  I am looking to fit a MAF kit and go to 1 bar boost which should get me upto 270-280 bhp but in reality my true reason for doing this is to irradicate lag rather than going for out and out power.  Since i'm looking to do a few track days a year my planned future mods are suspension (gettting sick of looking around for M030 so will probably go for an aftermarket set up) and brakes (probably 928S4 brakes but would like the big blacks!!).
 Either way Guards Red is the colour to go for!!
