Trickle charger for 718
- Thread starter bbbannister
Paul,PHB1969 said:Hi RayRay said:I have a similar set up to Ralphs although I do not use that much cable. I take my connector to the rear of the batter, up and onto the tray with just about 10cm cable/connector laying on the tray top.
If I knew how to post photo's I would but I cannot.
Ray
do you connect to both battery posts or do you connect to the positive and an earth point for the negative?
I have a permanently wired connection on my Vx220 and just plug in as you do. Probably need a charger for the 718. I do have an Optimate are they any good?
Paul
I connect to the batteries positive terminal and to earth on the nearside suspension strut mount. I use a Ctek but I do use an Optimate on my Boxster. The Ctek is more flexible in its charging modes (AGM stop/start battery function).
AGM (Absorbent Glass Mat) batteries are designed specifically for larger, more demanding stop-start vehicles that use additional technologies designed to reduce fuel consumption. ... AGM batteries can be fitted to all stop-start vehicles but must be replaced 'like for like' where an AGM battery was originally fitted.
Ray
PHB1969
Super - thank you Ray. Looks like I need to get one ordered.....Ray said:Paul,
Ctek MXS 5.0. My other is an Optimate 2. I do have a third which is a heavy duty charger for my twin battery Pajero SWB.
Ralph if memory serves me right has an all singing Ctek charger but the MXS 5.0 does ok for my needs.
Ray
PHB1969
Although mine is only just over a year, it’s only done 2k miles.....so unless it gets a good run, start/stop doesn’t kick in.....it is garaged but I know that one day it will probably decide it isn’t keen on starting....Ray said:Paul,
Sadly my vehicle only does mostly short runs nowadays and to keep the battery up to spec I connect mine every night. The battery take a beating in the winter especially with the heater, demister etc going.
Paul,PHB1969 said:Although mine is only just over a year, it’s only done 2k miles.....so unless it gets a good run, start/stop doesn’t kick in.....it is garaged but I know that one day it will probably decide it isn’t keen on starting....Ray said:Paul,
The battery has to be fully charged for the stop/start function to operate. Also other criteria come into play before it's operational.
Ray
Steve Brookes
Moderator
Ray said:Hi Guys,
I am struggling trying to place a photo on this thread. I have some images on the imgur site but where the blazes is the URL. I dont use hosting sites as I dont trust them so this is the first time I have done this.
Ray
I guess you found out Ray? Just in case, click on the pic and you get a choice of links to use. For the PCGB forum I usually use the 'direct link' and paste it into the pop up box that appears when you choose the picture icon to link a photo.
Steve,Steve Brookes said:Ray said:Hi Guys,
Ray
More by good luck rather than good judgement on my behalf. I shall try your method but when it comes to photo transfers etc I am not the sharpest knife out of the draw. Thanks for the info.
Ray
Ray
What I did was, right click the image and pasted Copy Image Location from the drop down box into the clubs URL box.
I have worked out your method. I was unsure what all the options were for down the right hand side of the selected photo. I still dont know what they all do but I do know that clicking copy on the Direct Link does the job. Thanks.
Ray
PHB1969
So...charging...if I open the bonnet.....the front storage area light comes on.....does it ever go off either after time or can it be switched off Or do I just lock the car and it goes off then....? Many thanks Paul
Paul,PHB1969 said:Ok...got mine and set it up this evening. Used the positive terminal and the battery clamp nut and bolt at the front of the battery. Lead comes out in the middle under the bonnet below the windscreen.
I am hoping you close the bonnet? If not, close the bonnet and lock the car. Although you can try Ralphs idea. Personally I wouldn't try it myself as her indoors would probably not unlock for me.
Ray
PHB1969
1 My Ctek MXS 5.0 seems to make a buzzing noise. My old one which doesn’t have the AGM mode does not buzz. Should I be concerned.
2. I believe the battery is an AGM battery, it’s a banner 80Ah 800CCA battery. Should it be charged using AGM mode? I know standard car mode uses a slightly lower voltage 14.4 vs 14.7.
what are most people doing?
Thanks, Paul
No idea about buzzing.
Do you simply attach the CTEK leads to the negative post and positive terminal using the supplied leads, not sure if vibration would dislodge them whilst driving ?Ray said:![]()
No stopping me now.
Ray
Neil
Dick Dastardly said:Do you simply attach the CTEK leads to the negative post and positive terminal using the supplied leads, not sure if vibration would dislodge them whilst driving ?
Neil
If you can look at the previous page, you will see how the under-bonnet connections are made
