I find myself in a bit of a quandry.
As some may know I swapped my 87 Turbo callipers and discs for SE callipers and 928 S4 discs (i.e. late model Turbo) some time last year.
This conversion wasn't without problems and required an addapter block (from Lindsey Racing) to mount the callipers, but all lined up OK. The discs and callipers were second hand and a little worn.
I now come to replace the discs and have remebered how close the steering rod knuckle is to the disc - as in the rubber boot is almost touching. With new unworn discs the gap is almost non existant.
During the first swap I assumed this was as per Porsche design and should be OK. Now, having interogated PET, it would seem that there are 8 allternative types of steering knuckle (thats the axel/hub carrier that mounts on the bottom of the strut). Great, whist I expected there to be a difference for the calliper mounting I am now assuming the the steering arm element has different lengths/andgles to accomodate the different discs.
My options as far as I can see it:-
1. Dump the SE set up, go back to my original callipers with drilled 28mm thick discs and uprate the pads/hoses. These are lighter which is a good thing.
2. See if I can get a set of second hand SE steering knuckles - a total pain as I've just had the geometry checked.
3. Fit the new 928 discs and hope all is OK - they havn't been a problem for the last year. As an indication of how close the worn disc is to the rod end - if you fold up a bit of card in half, the rubber will hold the card against the side of the disc.
What do you think gentlemen?
