Turbo cooling pump
I understand the T/Cooling Pump is part no: 951 606 130 01 and the Temp Sensor : 951 606 106 00.
This may give you or the Parts Dept person a pointer, your car looks like a late one so may-be there are later versions of these parts?
Good luck
Now where's that anorak[8|]
George
944t
I had to replace the turbo cooling pump on my a few years ago and it cost me
£145.59 with the VAT [:(]
that was just for the part
And finally I found the fault after countless checking. In fact it was two problems. The pump had failed and I sourced a s/h unit from PH Sportscars. Check the pump worked and replaced it, just in time before driving down to the ferry for Le Mans - that was several months ago!
The pump still failed to start after turning ignition off. After more checking I suspected the relay (part no. 951 618 149 00) and thought this should only be a few quid to replace........errr no, the OPC quoted £80+. Eventually sourced one from 'onlynine' ebay shop for just over tenner. This was just before a dyno day with R19 today. It now works! So no more 5 min idling to let the turbo spin down.
Which leads me to more questions and another post for my dyno results....another day I think.
ORIGINAL: wibble
C'mon let's see those Dyno results, you can't leave us on tenterhooks like that [:D]
Which Dyno was it at?
ORIGINAL: Diver944
ORIGINAL: wibble
I'll start a new thread once I get the results scanned. We used Surrey Rolling Road right next to M3. Good day out ...see pics on R19
