Turbo Overboosting
- Thread starter Guest
Chris Goodman
Hang on a mo - just to be clear - are you saying that the ONLY symptom of what you are describing as an "overboost problem" is that the standard boost guage reaches max reading?? If so - and certainly subject to what the more experienced owners think - you probably don't have a problem at all as (on my car anyway) the standard guage only gives a broad indication of boost pressure. To be specific, mine also hits the stop under max boost but according to the recent dyno day max boost is (only) 1.1 bar.
And if you've got a 'Superchip' as I have, I believe the overboost protection / cut-off is retained but set to a higher level appropriate to the remapping. Enjoy! (usual disclaimer of all liability applies....)
Chris
Diver944
The in car gauge reads up to 2 bar.
Normal atmospheric pressure is 1 bar, so if your needle goes up to the 2, that is actually 1 bar of boost + 1 bar of atmospheric.
If the dyno measured you at 1.1 bar of boost then that would be 2.1 on your in-car dash
hey, I got someones name right[
Chris Goodman
So...when the Porsche dash guage shows 1 bar (or less) with the turbo spinning no actual boost pressure is being applied?
Anyway, in that case I think my general point to Dan is even more solid as even on a standard car max boost should be reading right at the top of the scale on the guage. There's only a tiny graduation between 1.8 bar and 2.0 bar. Certainly not sufficient to make accurate judgements of overboost??
