Hilux
The ABS works with a magnetic sensor reading a castellated ring around the hub. How can it have the faintest idea what tyres you have on?
It can cos if its calibrated for a particular rolling diameter/circumference its accurate enough to know that something is out of kilter and that your tyre is burst or deflating and so warns you on the dash via the ecu/ABS (hence modern low tyre pressure warning systems are clever and cheap) []
Its true, if you dont believe me look it up []
