65 mat
QUESTIONS? Why didn't the factory use Magnesium "Cups" (as used on the RS and N-GT) on the Cup Cars and why didn't they have the above wheels manufactured with the correct offsets, so eliminating the need for spacers and extended wheel studs? Did the Cup Cars come with the extended wheel studs as standard? Cheers, Matt.[ORIGINAL: Hacki Use 225/45 x 17 front and 255/40 x 17 rear. Watch that you need the original 21mm spacers for the rear due to the offset. Neutral balance no problem with these sizes, it depends on the set up (ARB, camber, toe in, corner weighing, etc.) Not too much experience with wet weather tyres. Hope that helps, Hacki P.S.: These sizes are also the recommendation of the factory for road legal Cup cars.
