Tyre Wear
- Thread starter Guest
So booked in to Porsche Guildford and got a £250 bill for tracking check which found nothing wrong....
Go figure.
Anyone else noticed this phenomenon?
Peter
Maybe we should have some sort of poll on this? Personal experience (6.5K miles, 18" Continentals, std tyre pressures, usually 2 adults 2 labradors on board) noticable tyre wear marginally greater on the inside at front- but not excessively so will measure and report back.
Tony
Jamesec
BTW, when you think that the front tyres are coping with braking, steering AND power inputs, 15,000 sounds extraordinarily respectable for a vehicle like this!!
Has anybody tried the recomended Scorpion A/T tyres?
Rgds
Mel
>>I don't drive it hard<< That's what they all say[]
chris200100
OPC quoted £300 per tyre. I have rung around and got that down to £240. What I was told by one of the tyre places is that everyone should have their tracking checked every three months! I certainly wasnt aware of this.
Black80XSA
ORIGINAL: chris200100
my main journey is only 2.5-3 mile each way lots of stop start but I can't see how that would affect the tyres that much.
er... what do you think causes the car to slow down and accelerate? The main friction point between car and outside world is the tread on your tyres! (Paul's will last much longer because he's at a much more constant speed on a motorway).
(I completely accept that only 4000 odd miles is very low, but I don't think you can compare with motorway miles)
ORIGINAL: NIL98
.... Wear is pretty even, front and rear....
That's good - they must have the power distribution about right.
It always seems to me that there must be inefficiencies in the process if (on a 4 wheel drive vehicle) the tyres wear at different rates. But on my 993C4 the rears wear at least twice as fast as the fronts, and on my Toyota RAV4 the fronts wear nearly twice as fast as the rears...so neither have it right!
Changed to 20's with Continentals have to say lasted much longer with even wear, still going strong at 15k. IMO P Zero are pants...had them on previous Impreza's & at the time promised my self never to use them again.....there are much better around and found that to be so. 2.5 ton on p zero.... they can't cope.!
Monty2
Tyres I would never fit are Continentals had them on my Range Rovers and really had issues with aquaplaning and wear wise they look ok, they look ok and bang there shot to the tread wear indicator . I was about to buy a discounted stock new cayenne 3.0 D earlier this year but walked when I saw it was fitted with Contis and had 8 way seats with no lumber adjustment.
Hope this helps
Paul
