Tyre Wear
- Thread starter Guest
http://www.porsche.com/uk...ormation/tyreapproval/
Rintoul said:Hi looking at the link provided the pirelli scorpion Verde all season are on the list for cayenne 20" wheels also scorpion winters are listed.
duh ... apologies i was looking at 21 inch .. my bad
RCS
Mine is is a 2014 3l diesel Platinum, so pre facelift. Looking at the list from the link my model has the choice of Michelin's, Pirelli's or Yoko's, all N1 approvals. But if you look at the 2015 facelift model, same size wheels and tyres, the Pirelli is not listed and the Michelin and Yoko are different to the pre facelift ones. Is the facelift really that different it needs different tyre approvals? I know it has a bit more power and grunt (17 ps and 30 Nm I think), but the same tyres on mine can apparently be fitted to the pre face Turbo's!!
So as i'm still 'Porsche Approved' if i happened to fit the later tyres, whilst they are still N rated I guess that could make it invalid! I know I have to get N rated, but hadn't realised Porsche had added the additional twist!!! Naively i thought a tyre of the right size with an N rating would be alright.
tiskev
I cross the Jura often in winter and have no problems.
I did not realise untill i bought Swiss Scorpions that there are different specs
depending on where you are going to use them .The wear rate is unbelievably low on mine.
I believe you can get the higher spec Scorpions in My Tryes in UK ?
