V8 conversion
- Thread starter rd944
944 man
The 6R4's engine was a turbo and I'm pretty sure that it did not origionate from the Rover/Buick unit (Overhead cams rather than pushrods etc.). Intrestingly it was the same engine that ended up in the XJ220 (even though Jaguar/TWR would never admit to it), good for over 800HP in race trim. Now THAT would be intresting! AndyORIGINAL: sawood12 Surely you can get more than 350bhp out of a Rover v8 can't you? I thought the 6R4's were getting a load more than that with 2 cylinders lopped off. Apparently pretty much all Audi engines use the same mounting hole patterns so should bold upto a 944 torque tube. So why not an engine from the Audi stable? Apparently there are a few kicking about due to the Aluminium Audi A8's being difficult and V. expensive to repair after they've been pranged meaning alot are written off. A work collegue, who also likes to mess around with cars, is transplanting a 4.2ltr V8 out of a German A8 into an Audi 80 - just for a laugh.
944 man
The 6R4 engine was normally aspirated; and its nothing to do with the Buick V8. The engine was used as a base for the Jaguar XJ220 engine, in which guise it was turbocharged.ORIGINAL: andygreyThe 6R4's engine was a turbo and I'm pretty sure that it did not origionate from the Rover/Buick unit (Overhead cams rather than pushrods etc.). Intrestingly it was the same engine that ended up in the XJ220 (even though Jaguar/TWR would never admit to it), good for over 800HP in race trim. Now THAT would be intresting! AndyORIGINAL: sawood12 Surely you can get more than 350bhp out of a Rover v8 can't you? I thought the 6R4's were getting a load more than that with 2 cylinders lopped off. Apparently pretty much all Audi engines use the same mounting hole patterns so should bold upto a 944 torque tube. So why not an engine from the Audi stable? Apparently there are a few kicking about due to the Aluminium Audi A8's being difficult and V. expensive to repair after they've been pranged meaning alot are written off. A work collegue, who also likes to mess around with cars, is transplanting a 4.2ltr V8 out of a German A8 into an Audi 80 - just for a laugh.
Yes, sorry it was N/A. AndyORIGINAL: 944 manThe 6R4 engine was normally aspirated; and its nothing to do with the Buick V8. The engine was used as a base for the Jaguar XJ220 engine, in which guise it was turbocharged.ORIGINAL: andygreyThe 6R4's engine was a turbo and I'm pretty sure that it did not origionate from the Rover/Buick unit (Overhead cams rather than pushrods etc.). Intrestingly it was the same engine that ended up in the XJ220 (even though Jaguar/TWR would never admit to it), good for over 800HP in race trim. Now THAT would be intresting! AndyORIGINAL: sawood12 Surely you can get more than 350bhp out of a Rover v8 can't you? I thought the 6R4's were getting a load more than that with 2 cylinders lopped off. Apparently pretty much all Audi engines use the same mounting hole patterns so should bold upto a 944 torque tube. So why not an engine from the Audi stable? Apparently there are a few kicking about due to the Aluminium Audi A8's being difficult and V. expensive to repair after they've been pranged meaning alot are written off. A work collegue, who also likes to mess around with cars, is transplanting a 4.2ltr V8 out of a German A8 into an Audi 80 - just for a laugh.
Diver944
sawood12
