Resurrecting and hopefully bringing this post back on track, a question/conundrum for the collective:
I’m running a std block with stage 1 intercooler, custom 3” exhaust and downpipe VEMS with wasted spark, LR recirc valve, LR Super 53 8# P trim turbo 3bar fuel rail with 630cc/min injectors. I have been running the LR DPW for years on MBC, but have struggled with EBC setup and boost creep at high RPM, so swapped it for a Tial F46 recently. My problem is that the Tial is apparently causing wild boost surge and not controlling the boost at the expected spring pressure (fitted it with 1bar spring initially with overboost everywhere, then 0.6bar spring which is now giving this boost surge). See the picture for a snap of the boost surge (this is not overboost fuel cut).
It is not a vacuum/boost line setup issue or leak, I know the config for the LR and tial gates. I’m not currently trying to control boost, just let the gate do its thing. I’ve statically checked the gate and it appears to operate as expected (albeit slightly higher pressure than the published figures, but within tolerance). You can see from the image that the gate is cracking open at about 70-80kPa as expected, but then not controlling the boost at that level.
I suspect a dodgy gate but can’t understand how or why. Has anyone else ever come across a similar issue? I will be re-fitting the LR gate next week when I can get hold of a std dump pipe again (after modifying my current one to fit the tial).
Worth noting that I've run the car with the wastegate dumping into the exhaust as normal, and also dumping to atmosphere (very noisy!) to check if there was a back-pressure issue. It made no difference to the surging issue.
