very rusty sills
- Thread starter Guest
NeilW
Yes I think you can get cheaper, non-galvanised, sills elsewhere. Club Autosport (www.clubautosport.co.uk) do a repair panel. If you're planning on keeping the car the OE panels make sense.
Before spending money though it may be worth having the car inspected. If the outer sills are as rusty as you say then I'm wondering how bad the inner sills / floor pan / box section are. Bearing in mind that the sills tend to rust from inside out.
Good luck.
db@944s.co.uk
I am doing the same repair with Club Autosport panels just now. The existing sills only looked "bubbled" but the bodyshop manager says the old ones are rotten. However the rest of the underside is fine.
I'm having photos taken of each step of the repair before a full respray and I'll post more photos as I get them.
Paul Fraser
Interesting post db, although I thought the repacement sills were the bit under the door. Do they extend to the rear quarter as well?
PS I'd be really interested to know the costs and location of your bodyshop as you are quite local to me and I could with one of mine fixed.
db@944s.co.uk
£188 inc del & Vat from Club Autosport.
db@944s.co.uk
The bodyshop is GS Autos in Dunfermline and the phone number is 01383 626800
If you supply the sills/quarters he is quoting approx. £300 including painting
Paul Fraser
db@944s.co.uk
Attached is the photo from Club Autosports website.
The bodyshop has repaired one side so far. I'll post photos of the repair next week.
Fred Hindle
The cold galvanising paint is available in spray cans, if you are interested I will find a can in the garage and let you have the details.
I bought my cans from an autojumble some time back - £1 a can or six for £5
Used in on my trailer, worked a treat.
Cheers,
pauljmcnulty
One thing is for sure, there won't be any shortage of cars needing sills over the coming years [][]
sawood12
Hilux
Scrape it off until it is stuck and you will see bare galvanising then rust treat and waxoyl.
I'm gradually running along each sill clearing drain holes and treating the minor rust on edges etc and then coating with waxoyl before replacing the skirts.
db@944s.co.uk
db@944s.co.uk
morris944s2john
Only thing that worries me is did they use weld thru zinc primer on the inside of the repair?? Other wise rust could start inside the sill again very soon. Best to waxoyl inside after you've got the car back and are happy with the work.
db@944s.co.uk
No filler ...
