Has anyone experienced a situation whereby the car and starting wheel shudder under hard acceleration? It seem worst between 50 & 70ish. The car is a second generation turbo.
Vibration under acceleration
- Thread starter Patrick Aschan
Greenman986S
Bad prop shaft?
I don’t think it’s that as she still pills very hard.Sounds like a misfire
Spark plug or coil pack going?
Worth plugging a code reader in to see if its thrown any codes
That’s what I’m worrying about. May have to talk to my servicing dealer.Bad prop shaft?
Hi Patrick,
Firstly, I’d make sure that your wheels are properly balanced - the front in particular - and that there’s are no defects in the tyre sidewalls or treads. If that doesn’t cure the problem, ensure that there’s no play in the steering and front suspension assembly, the driveshafts included.
Hi JeffHi Patrick,
Thank you for the suggestion, I know that the wheels are fine as I recently had the balance checked when I swapped to my winter wheel & tyres. I think a trip to the dealer is called for...
Patrick
Greenman986S
Does it vibrate in the same speed range regardless of gear?
Only on acceleration or at steady speed?
As above Patrick, if the vibration gets worse when accelerating through the 50-70mph range rather than on a balanced throttle - i.e. lifting the throttle slightly - it would indicate that the problem most likely is due to a transmission/driveshaft issue. However, these types of problems normally get worse progressively unless some component has failed suddenly, and you haven’t indicated whether or not this has been the case.
