WARNING !!!!! PAS Pump Power Assisted Steering switch..LOOM RISK
- Thread starter robwright
PSH
jellytott
I was in the process of resolving a Oil Cooler oil leak getting organised ordered parts sourced the align tool (Thanks to Alsdair), cleaning down the oil soaked area ready for the job, thought nothing of it so next day started her up in a short period of time had erratic oil pressure and battery volts too. Here I genuinely thought it was caused by the area I hand be exploring the day before but the damage had been done.
The loom (the American forum suggests its called the DME loom) carries the cables from the bottom end of engine (Oil cooler location) for oil Switch and PAS switch and also low oil level switch up to the front of engine and then joins the injector loom underneath the inlet manifold runs over top of engine block then to bulk head I assume possibly to the connector (14) on bulk head battery side.
I have to say I feel like a right knob looking at the burnt cable damage now, Has anyone else had the similar unfortunate experience and more importantly replaced the loom...so any advice given would be well received now as I look to resolve it myself.
Yes the car runs still but is layed up with battery disconnected !!
