Washer jets
ORIGINAL: robwright
I thought they came on with demister/mirrors but not the case.  They are always on.  As for tank water & bleach mixture, flush it several times through the jets having let it sit for a while.  Then flush the whole system with a couple of tanks of clean water.  Note to all stick to one grade/make of screenwash.  I use winter grade all year round.  Probably because I have hundreds of litres of it at work [:D]
Very interesting - and I will try that.. thanks
So - a few tanks of thin bleach and water and just jet the lot through?? Bleach wont damage anything around the screen etc???
Then a few tanks of water to remove bleach etc.
Then fill up with washer fluid (will prob buy Shell as thats where I get petrol)..
People are going to look at me weird Sat morn when I am constantly washing my windscreen for an hr... lol..
There's a non-return filter-valve thingy where the feed splits to the two washers. It does block up.
Don't remove it, because the wipers come on with the washers you don't want to be scratching dirt over the screen whilst waiting for the water to pump up to the jets.
ORIGINAL: pauljmcnulty
Ah OK thanks - so this can be removed , cleaned and put back?
Whilst we're at it :)
I have an almost blocked jet , how the hooj do you get them off
I can't see how you do.
Cheers Mas
You can remove and clear the non return valves by soaking them in white vinegar, I used a large syringe to force solution through the valve to clear it similarly you could use a large syringe connected to the back of the jet to force water through to check if it is the jet which is blocked.
It is usually the non return valves which block and even when cleaned can stick shut and stop the water getting through you could remove them and temporarily joint the washer tubing to test this out. Genuine Porsche non return valves are about £15 for the two for each nozzle, but I think you could use one from any car such as a Volvo or indeed some kit car part suppliers have these, you only need to match up the fitting to the internal tube diameter.
I have my man do it for me, don't you know....[8|]
Sad, but I got RPM to fix mine last service. Toooo lazy! [:D]
ORIGINAL: ukmastiff
Mas,
They unclip. You need to pull the pipe off the back of them and cut the wires (no plugs in the heating wires, but you could put some in easily if you are going to make a habit of removing them). Then slide them forwards, towards the front of the car (I think). From recollection, there is a clip underneath that you can squeeze as well, and they lift out of the bonnet. Take care not to chip the paint while doing so.
I say cut the wires to the heated jets anyway before they short out and you end up getting smoke through your vents!!!! Once the car has warmed up the screen will clear anyway!!! Why do they need to be heated?
They are heated ? You could have fooled me !
Every time there is a frost mine stop working [&o]
Hmmm, the arrogance of S2 owners, altough 'those in the know' appreciate the rarity value of the 'S' especially in the fastest of colours [;)]
My drivers washer has always been really lame. Had a shufty today and replaced the non-return valve Tee Piece with a £2.49 Halfords part. Now works a treat and is pumping gallons [:)]
ORIGINAL: Bob
ORIGINAL: the_dr38
It stops them freezing up so you can actually use them
But they will surely warm up as the engine warms up, after all they practically sit on top. Plus the water isnt getting warmed up so even if the jets work the water squirting onto the screen is only marginally warmer than the ice on the screen, which doesnt make much difference anyway. I have never had a car with heated jets before and had the jets freeze up.
Anyway its something you can tell other car owners about.
Lloyd
