ORIGINAL: Mark Bennett
When you rinse, try rinsing the car off with the hose as usual, then turn the tap right down and hold the hose close to the body and let the water run on to it without causing a spray - the water will "sheet" off and very littl will remain to be mopped up.
Use a microfibre drying towel, and a smaller microfibre wipe straight after for the last remaining film.
Alternatively after following Marks procedure up to "mopped up" Get the Autoglym Aquawax out and spray each panel with a few squirts then carry on from "Use a microfibre etc" and you have just carnuba waxed your car in one easy step adding barely an extra 3 minutes or so to the entire procedure [
