sawood12
The surge/judder sounds a bit ominous to me. Not in a serious way, but in a way that sounds like a tricky problem to track down - it could be fuel or electrical. It certainly doesn't sound like a wastegate issue as a leaky premature wastegate will just increase lag and in extreme cases you might struggle to achive full boost. However surge/juddering is not a wastegate symptom i've heard of before. I think what Paul has said makes sense in that you should give the engine a damn good look over to look for boost leaks, any electrical problems - for example are your HT leads the originals?
If your wastegate is the cars original it will almost certainly be way past its best.
