Watchdog Is On The Case
- Thread starter daro911
nottage
The technician said it was probably because when he cleaned the car before putting it back in the garage it was still wet. However this is not the case as my uncle always takes the car for a quick spin to dry it off before he puts it back to bed.
The technician then didn't know what to say, except you will need new discs soon and that will be ÂŁ1000.
I have emailed him the above so when he gets back from holiday he can get in touch with Watchdog.
Kevin
JCB..
Non-member
More likely the disk material is faulty.
Plus probably lack of use and the fact that Poole is at the seaside!
and
1k for new disk and pads? I replaced my own front disk and pads (no previous experience whatsoever, just used help from this forum), parts from Eurocarparts.com, and it cost me around ÂŁ110 and took 1.5 hours total.
It's a shame they aren't chasing the real story.
JCB..
inside of the discs were corroded and that will be ÂŁ1000 please for a new set.
This is real pain since you cannot easily inspect the inside of the disk
Elliot Davies
Chunks missing from them !
Are they made of Cheese ?
It stemmed from this postORIGINAL: NicD
this is new on me. I cant recall complaints on this - Top Bear, what is your story? Did your disks require to be replaced?
When I put my 03 S in for its first service with just 8K miles on the clock I was told by the service mgr that the discs were both scorched (on the front) and corroded (on the rear) and that they recommend all the discs and pads be replaced as they were in a 'compromised' condition. Granted the car had been dropped off the day after a track day
I then argued the toss about the durability (are rather lack of) of the rear disks regarding the corrosion, to be told that this happened because the car is left sitting for the most of the week and only driven and weekends.
So my thoughts on the Boxster's brakes were that your damned if you do use them, and damned if your don't.[&:]
thboxster
So it probably isn't an uncommon money spinner, although this was BMW.
ORIGINAL: thboxster
I suppose there is some merrit in their statement about them being corroded due to lack of use. I have experienced a similar discussion with a service dep't, but they were a little lost as to what to say when I explained to them that the car gets used everyday and it's never left for any lengthy periods without use.
Yeah and in my case a 'long period' was from Sunday night to Thursday night every week, not exactly what you would call a car 'holiday'.
What gets me is their ridiculous attitude that 'we make quality, durable high-performance components, but if you dont use it everyday, then it will fall-apart and you will need to replace it within 12months'........eh!!??
But unless I'm missing something, yours are left in a covered area Nic, some have to park outside.
Mine is garaged, and so far the discs have been ok (30,000 miles in 3 1/2 years, but still long periods of inactivity)
I have taken to taking the car for a quick dry of the brakes after washing, but only in the last year or so...
ORIGINAL: TopBear
... and only left outside over the weekend.
When it is being used, therefore the argument of it being left damp is invalid!
Tool Pants
non Club member but v. knowledgable
I have seen Cadmium discs on ebay and it is said they do not rust. Maybe Porsche should try them.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7938198593&rd=1&sspagename=STRK%3AMEWA%3AIT
Definitely something not right - more annoying is that cars I have had that cost less than 1/10 th of the price, have been used twice as hard and cared for far less have had no problems like this. Not what I would expect from a Porsche.
ORIGINAL: Cary Blackburn
Do the older 911's have this problem ...
993 models have exactly the same problem. Common enough that any independent will tell you they see lots of these on the 993.
