Just to add to this tread ...been an owner for years and never had issues (tempting fate) with water ingress in any of the Boxsters 986x2 /987x2 /981 x1 could someone post pictures as to where the drain holes are on the 981 as this gets used in the wet , The issue is if you have to get access to the front lid cover will require the removal of the Ctek battery connection before the tray can be completely removed as the cable is passed through the tray .where are the drain holes next to battery looked in and nothing visible ,also where are the ones in the rear and how do you access them ,a link to a vid would be good have a long length of net curtain wire to use .thanks in advance .
Just watched a vid showing drain rear hole and pouring water down it and pours out on the ground back and front surely you push some roading down first to clear any possible blockage if you have a blockage surely pouring water down will only add to the problem of wet carpets or am I missing some thing .
