waxoiling inside my sills
- Thread starter Alpine
pauljmcnulty
John Maddox
When I did the proverbial screwdriver test it, of course, went straight through.
I tackled mine myself and cut out the rust ( quite a small amount really) and filled it after ensuring all major rust removed. Then applied the correct rubberised crinkle finish (Wurth I think it was called - from Frost Supplies) which has the added advantage of filling imperfections. Then I sprayed it from an aerosol - my wife say's she cannot see the repair so it's probably good enough and rust hasn't re-occured yet.
I then took the plastic vents of the door and door frame carefully so I could see the enclosed sections. The door was fine but looking back towards my repair was not a pretty sight !! Rust appeared to be all along the lower sills towards the wheel arch. I injected rust killing wax towards the wheelarch on a warm day so it flowed well. I used Dinatrol 3125 (I think thats correct Number) as it won the Practical Classics test a couple of years ago.
Then I noticed a few tiny bubbly bits along the sill towards the front. You can gain access to this part of the sill by removing plastic bungs under the inner sill carpet. It looked reasonable in there so I injected more rust killer wax and did the whole process again on the other side. Mind you don't block drain holes if you do this.
You can't see too much through these bungs as the inner sill blocks vision.
Sorry this is a long post - having done all this I have stopped worrying about it and I hope I have slowed the tin worm to a crawl !!
Let us know how you get on.
sawood12
ORIGINAL: sawood12
I struggle to understand how condensation can form between the metal skin of the sill and the applied layer of waxoil or similar product. Condensation forms by moisture in the air condensing against the cold metal surface but if there is a layer of waxoil the air is not coming into contact with the metal skin. .......
Ed Zachary! [
My point (obviously badly made) was that if people were content that, by filling a section with lots of waxoil, there wouldn't be a problem with water getting in subsequently this wasn't the case and water would still form within the section through condensation.
To go back to the earlier point. If you try to coat a cold piece of steel with anything on a damp day then the likelihood is that there will be condensation on the surface of the metal. As to whether waxoil will repel that condensation prior to sticking to the metal I wouldn't like to surmise. If it did (which I doubt) the repelled water has to end up some where.
You perhaps get the impression that I don't hold with waxoil but this is far from the case. Waxoiling is far better than doing nothing, I am just suggesting there may be effective and less effective ways of doing the job.
I am a great believer in waxoil and waxing generally. I had a black MkI Capri with sundry rusty spots which, on the underside were retarded by waxoil and on the paintwork were retarded by regular waxing - the latter I employ today on Beaky and have every confidence that I will be very soon looking at the waxoil route as well.
sawood12
944turboS
Excellent idea Paul.
I had been thinking we should try & get a profesional allong to the Dyno Day as there is plenty of time available & lots of cars to prompt a group buy.
Hilux
It sounds more and more like we need to organise a Register waxing day.
Mentioned it too the wife and she said she`s coming along too so as to have a manicure and her highlights touched up [
Fred Hindle
Cheers,
sawood12
Alpine
Dinitrol probably is better if the comparison tests in certain magazines are to believed, but there probably isn't really that much in it.
