GeoffLambourne
I've had a complete new set of discs, pads, sensors and a bore score inspection (all good). Also a new oil pressure sensor and a door switch which hopefully stop my windows opening by themselves
I was originally using an Alex short shift kit, with the updated bush for the left-right level. Even after my gearbox rebuild it was still quite notchy so I then changed for a 997 GT3 shifter which is slightly shorter than standard (but longer than the Alex kit). Ideally I would like something between the 2.the baron said:I’ve been looking at those can you remember which combo you chose?
did you use your existing shifter gator and just cut it down? how long did it take for delivery
sorry for all the questions
the baron said:Thanks for the details, it’s exacly how I specked mine but without pulling the trigger, although you have concerned me re the engraving on top being a little delicate especially as I wear a wedding ring, did you infill your numbers with à colour?
Hugh_G said:Driven it and loved it. Needs a wash now though:
