What have you bought your 944 for Xmas?
- Thread starter Eldavo
vitesse
Yet to take it the tank out but looks like there has been a small split on its base which has increased & now when hot,just lets coolant leak out when very hot.
Quite frankly ,it's a relief as with other jobs needing to be done both on the car & at home,& on a model railway layout for my grandsons,I don't think I'd find the time before Curborough
vitesse
Tomorrow might mean I have peace of mind again with coolant tight engine ,correct oil pressure indication & gastight rear hatch.
Frenchy
Driveshafs getting a make over, but project halted due to some suspected corrosion at the bottom of the drivers wing being the case, getting sorted then project continues, i would hate to get weld splatter on my shiny callipers.
current: 92 968 Tipo
94 993 Manual
64 356
vitesse
Really agree []jasonp said:Called James today regarding a fog light unit-pass side,,,,
a very nice and helpful chap,,,,
Fingers crossed,,,,,jasonp
Tony,,,,Tony Maddocks said:Hi there, my Grand Prix White 968 has Dark Blue leather seats/ vinyl backs. As usual, from what I have seen in other cars the right hand side of the seat back has worn through and I wondered if the same colour leather is available from anywhere? ie Germany. This material and colour is also prevalent in 964's of the same era. Maybe someone could put a name to the colour? Cheers!
94 993 Manual
64 356
You may want to give Soutbound trimmers a call,,,,
pretty sure they will be able to sort it but they are so very busy so you might have to wait if you have the work done by them,,,
They will send bits out,,,i had the headlining changed in my last s2 and that was sent out for my chaps to fit,,,,,jasonp
vitesse
So,no need for head overhaul,nor oil pump investigation.Moral of the story-don't buy spurious oil pressure senders from ECP,but it was a lot cheaper.have to admit that I have never had problems with other non OE items from ECP
