Helen Goff
No.1 Poster
just bought a 1989 944S2 and am wondering what oil it should have in it? owner didn't have a clue (bit worrying) and i can't find any grades of oil mentioned in any of its service history.
'Tis what I use.ORIGINAL: oilman
10w-40 semi synthetic with regular changes will be fine
wow hadn't realised i was opening a can of worms. now totally confused but am enjoying learning.
ORIGINAL: zcacogp
And I subscribe to the theory that using a less-expensive oil and changing it regularly is a better bet than spending a fortune on it and changing it infrequently.
ORIGINAL: pauljmcnulty
Lol, bet you've missed 944 ownership! [][
What Oilman said is all you need to know. 5W is too thin, semi or fully-synth depends on your budget and preference but change it regularly and you'll be fine.
For the UK climate Porsche spec oils in the range of 5w40 to 15w50 irrespective of mileage.
This debate will rage on till the end of time it seems!!
Bearing clearances have not changed over 20yrs or engines will be seizing. Piston rings are an interference fit in the cylinder so there are no clearances.
If you reduce flow by using a thicker oil you reduce both of these properties.
ORIGINAL: Hilux
Consider what was around when the cars were new, no synthetics.
