Copperman05
Ha Oil again.... Dont we love this subject... There seems to be a lot of myths and old wives tales surrounding oil and its use in our cars. I always seem to hear people saying fully synth oil wasnt around when are cars were made, well they def were and are even recommended in my 1989 944 manual (Simon will dispute this as that is what he likes to do) but the fact remains there in black and white, if your car doesnt have an issue with leaks, then there is no reason you cant use 5W oil, 5W is just the cold temperature rating after all, 5W-40 10W-40 amd 15W-40 all have the same viscosity at working temp so wheres the issue, they are the same thinkness at working temp...
This debate will continue and so shall the differing views, which one you agree with is up to you, personnaly I use 5W-40 oil in my 100,000 mile engine and it runs at 3 -4 bar pressure at warm idle and does not leak or use any oil. If I were you I would invest in the future, as oli says, a cheap oil changed regularly will be better than an expensive oil changed rarely, but I would take it a step further, a good quality fully synth ester based oil changed regularly will offer you the very best wear protection available, you then only need to decide what viscosity oil you need and that will depend on whether intend to use the car mainly on the road, track or a mixture of both...
Edd
Edd
