I wonder why people here in europe buy grab turbos from the states.... These Lindsey units are so badly built, that i am not suprised you have low hp figures. Design of these "high tech" chargers is from '50's, mainly their wheel geometry is not what is should be. If you have a possibility to measure the pack pressure, i suppose you understand what i ,mean. These Lindsey chargers are also very poorly engineerd, parts do not fit as they should. Two friends of mine were at the dyno several years ago. Another one had the same Lindsey unit you have installed into his 951S. Problems started when there was less than 300 hp, pack pressure was just amazing.Car produced 330hp. Otherwise stock except this "High-Grab" unit + AFM Link MAP coversion with Guru chip set. Another 951 used KKK26/6 modified Holset turbine & compressor wheels. It also had same AFM Link MAP systems addes. It produced 350hp. So modified KKK was much better than "high-tech-US-made" thing.
We have a lot turbo knowledge in Europe, do not belive what americans say ! I have seen so many times badly designed US made turbos, i wonder do they not even know the basics how to build a decent turbo. We have had great results with Holset chargers (made in UK) installed to 951. I can highly recommend them. Skip those Lindsey units, skip even Garrets, their wings are not even close to what Holset have.
btw. my friends Lindsey "Super-Grab" lasted about 20000km's. After that it caused a huge oil consumption. It was all torned out and it needed a major overhaul. A local Holset guru rebuilt it. There is now a T04 compressor housing with Holset wheel. Turbine housing could be used otherwise it was more or less built with new parts. Car wheels totally different now. When snow melts and polar bears go back to north again, it's time to make some dyno measurements.
It makes me sad to read also in UK based forum these "Stage-things". Please leve that to americans. Only in america you should have all so "Staged", they are not so innovative as people are in europe,Australia,NZ etc.etc. so all have to be designed ready for them and after that "Staged" [
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Even some americans are against this stage thing, even John at Vitesse racing. He sells "Staged" things even him self, but he once explained me it is a must with americans [:'(]
When we compare this "Stages", is it some official system, like metric system or something else. It's hard to compare Lindsey Stage something for example to Vitesse or Promax Stage something.
Here's pictures of that Lindsey unit (our Holset Guru suspect that they have used some chinese parts with these...)
Here's what my friend wrote on Rennlist concerning this "Special-Charger":
While I do not have any own car to work on/in/under, I changed turbo to my friend's car. Initially it was supposed to be a rebuild, but it became something bigger.
Reason for the rebuild idea was heavy smoking and thus excessive oil consumption. There was A LOT of play in the shaft, which appeared quite fast, without any signs of unbalance of the compressor wheel ( no marks in blades ).
I took the turbo to Garrett's official importer, and their comments of this particular item were shocking. "WTF is this puzzle, and where it is bought from? Seems to be built from various & mysterious parts. It's sad when people buy expensive polished s*** when there's OEM or reliable aftermarket ( = Garrett / Holset etc ) items available cheaper. I guess that there were no compressor charts etc available... "
Oh well, there was some problems with boost threshold with this particular turbo...it spooled at 4+k rpm ( totally lifeless below ) and produced 330 crankhp while my own modified spooled at 3,5k and did 350 crankhp with all other engine mods being similar back then.
And this was not all. When the turbo was disassembled, some oddities were found, or should we say mismatches. Turbine wheel was so big that the compressor housing was machined too big, no diffuser area left. It was also not mated with the backplate...there's the notch where it should be in.
See this picture from Garrett's page, espacially how turbine wheel sits in the housing and the backplate. No such thing in this creature:
Somehow it was just raisd above it with spacer. No wonder that there were no boost below 4k. "This compressor has nothing to do with charging of air!" was the comment. The shaft's seal was of ancient coal/carbon type. The meaning of this was not quite clear to me...but apparently it was not to date.
Center piece had to be changed too, there were some threaded ( but plugged ) holes comprimising oil and water separating. The good news, shaft, turbine wheel and housing could be used.
Now it has TO4 compressor housing with appropriate wheel. It will be dynoed during the spring, but it should work better...
