What Tyres
- Thread starter skendrick
Touring or trackdays...?
carlmthompson
For Road use I had Avon ZZ1's on my old BMW (the size was 235/45/17's). I found that the previous Michelin HX Tyres (225/50/16) had far more grip in both the wet and dry, and were far more predictable when they let go.
I can also vouch for the Continental Conti Sports (in 225 & 245) on my current Porsche.
I have heard that N rated tyres are far more prefferable (article below sheds some light).
Hope this Helps!
tyre article
skendrick
Touring will be the main use, I havn't convinced the other half that a track day would be good for the car (and me).
I do around 7,000 miles per year and would like them to last at least 10,000miles if that's possible.
Carl,
Thanks for the article I will read this tonight, I have noticed that even in mildly wet conditions when I put my foot down to overtake the rear end is twitchy. I still have around 4mm of tred so a couple of months to go.
I can't believe the car should be so twitchy but then since i've had the car I havn't had a decent day's driving (warm dry weather, that is).
Thanks for your input.
Steve
skendrick
I am considering Toyo's next but didn't know if anyone had other ideas. But as you say each to their own. The price is good too.
Steve
NorthernBloke
Michelin's for me, although I was running Uniroyal RainSports on the back which were, as the name suggests, superb in the wet.
I've now got Michelin Pilots SX MXX3 N2's 205/55ZR16 on the front and 225/50ZR16 on the back and they are spot on
Diver944
You shouldn't really have a twitchy rear end under power though 4mm is pretty low tyre tread if its really wet. How old are your shocks? Worn ones may not be controlling things as they should. Even if the front ones are gone and the rear are ok, then the front may be rising too high under acceleration causing imbalance
John Maddox
Now on Kuhmo Ecsta 712s and find they last well, are quiet and grip reasonably. Very good price from Mitcheldever Tyres near Winchester.
I have Bridgestone S02 on the back and Michelin Pilot Sport on the front just now.
ORIGINAL: Fen
You're not joking, are you?[
I had Goodyear Eagles on my 944S2, couldn't fault them -still may have a spare rear in the garage if anybody interested?
Mel
ORIGINAL: Melv
ORIGINAL: Fen
You're not joking, are you?[]
Of course I'm not joking.
I personally don't give a bollox for all this "keep the same tyres all round" nonsense when I have 265/35 on one end and 225/40 on the other and most tyre ranges construction changes from one size to the next. Virtually all tyres aren't front or rear specific, nor are they driven or undriven specific and every car has different dynamics and weight bias. Do you seriously think that Bridgestone or Michelin designed their tyre ranges with any consideration of being used on a 15 year old car with non-standard wheel sizes? Or even the specific combination of sizes I am running? 225/30 18 is a hot hatch size these days so it anything they're probably designed with suitability to 200+bhp FWD in mind.
Does it make the handling less predictable having quality tyres on the front of a different brand to the quality ones on the rear? Of course not, the car does just the same in a given set of conditions every time. I agree that might be different to what it would do with 4 tyres of the same type but I refuse to accept it is necessarily worse. It might be of course, or it might just be different or it just might actually handle better with a mix.
My Pug has 4 tyres the same size, hence it wears 4 tyres the same but even there I don't think it's inherently bad to have different tyres front and rear.
lali
Kevin Welch
Very pleased with both but if its down to cost then the Toyos win hands down.
jr2015
I`ve used my 944 all year round as a daily driver for the last 12 years,and unlike Fen , prefer to use the same make front and rear.Over the years ,as a result of this I`ve only used two brands in this time. For the first 5 or 6 years I used Pirelli p6000s and then changed to Michelin pilots and have to say that the Pirellis were more "descriptive" of the surface underneath the tyres with a tendancy to tramline, whilst the Michelins make the car feel more planted on the road whatever the weather.I`d recommend them.205s on the front and 225s on the rear work for me too.
regards,
jr.
i use Falken FK-451 for both track and road use
it says i am a non member but i am a member how do i change this
Edited by Paul - Al, unfortunately the forum does not link automatically to the club database so you need to confirm your Name, Membership Number and Forum Name to Club HQ (email cluboffice@porscheclubgb.com).
