Interesting reading every-ones thoughts.
Mine would include moving the Handbrake to the Centre tunnel, (like an MX5[>:]). The reasons are its up and in the way when you have to get in & out, its impossible to co-ordinate on T-Junctions or in a Yard with a bit of Drifting potential[
], and when you get in, its Key in the ignition(Right Hand) /Handbrake release(Left Hand) Belt on (Left Hand), except this routine is messed up with the Handbrake where it is.
I like the Pop-up Lamps, they are good for positioning the Car on Minor Roads. Car's like the Toyota GT4 were rallied with the lamps up and lights off for this reason. Also useful for parking I find. Plus I like the fact we have them when some Bureaucrat has deceided they are unsafe - prats.
I often thought the handle on the A-Pillar on a Honda was useful for getting out, but never thought it would suit a Porsche, so perhaps not?
The Rev Counter should be in the Centre of the display, the Water Temp should be visable.
More space for the left foot in the tunnel.
The Gear Lever should be moved 40mm to the Right, (the Tunnel seems to be optimised for Left hand drive)
The Sunroof should have been like a 1990 Honda CRX, up and out - slide back, or deleted[8D]. (But in 1989 for ÂŁ43k I suppose it had to be there[
A standard equipment Laser Jamming device perhaps[8|] - the stealth approach. Call it Hazardtronic, a safety feature to warn of danger.
I love the Engine Note, but the Turbo should have been bigger, the Flywheel slightly lighter, and the Cars should have been 350bhp in std trim.
The Doors / Bonnet / Torque Tube should have been aluminuim, or lightweight Alloy, leaving the Car at 1200kg. A 951RS version with a Cage, no AirCon, no underseal, no Sound-proofing, 1 sunvisor, no clock[
], Seam Welded, Recaro's, - at 1050kg, with a 2.7 eight valve and a bigger intercooler with 380bhp? Maybe a few Vents in the alloy bonnet / nose-cone?
If only they had remained committed to the Model, what a Car the 2.7RS would have been, - and i'm not thinking '73.
KW suspension[
], PCCB[
], Carbon Rims[
The 911 has loads of replicas, & re-creations. If some-one did the same for a 951 - what a car could emerge.
George
944T
964rs
