Whats the worse job on your Model ?
- Thread starter chrisg
Monkeythree
My top difficult job; changing the oil pressure sensor. 'Tis a pig of a job due to poor access. Next one would be changing the clutch - not hard, just very (very) long!
(I should add that I can't comment on the tribulations of maintenance on a turbo as I own a >cough< superior S2!) [
edh
Engine mounts on a Turbo - didn't enjoy that at all, felt like giving up several times...
I'd also have to mention the engine swap that Chris helped with/masterminded... He went off on the Sunday to see his mum, before the new engine went in. I think it was probably some time that evening I saw the text he helpfully sent me just after he left: "don't forget the reference sensor" [
chrisg
I have found though, (and I could be biased..... a tad...) that working on the 951 is pretty straightforward as everything is metric and 10, 13, 15,17,19mm for most straightforward stuff - albeit access (particularly the oil sender Oli ....) is a PITA. Yes, you need 32/27mm spanners for the belt rollers and the oil cooler pipes oh and a deep 24mm 6 sided socket for the crank pulley bolt, but everything else is bog standard metric/generic service station.
chrisg
Ed - yes juggling a 944 gearbox (even without ~ 2kgs of hypoid) is hard work:
1. You've a heavy diff unit in there as well (compared to a lower weight RWD gearbox)
2. The Balance/ CoG is all over the place and makes moving up and down hard work - after all its designed for an Audi Coupe with all the weight backwards away from the diff/input shaft.
Tony
I imagine dropping the TT out of the rear axle is hard work, never had to do it myself - I dropped the rear axle to do the brake & Fuel lines, messy/dirty but not difficult.
Ref. the caliper lift, for a home mechanic ( i.e. without gas bottles etc) it can be very difficult to get enough heat into the retaining button screws. I did my front caliper last year, managed all but one of the 8 for 2 x calipers on my own then had to get a local friendly mechanic to remove the last one !
I guess the bottom line is that because of the age of all of our cars, by default (unless theyve been apart or replaced) all of the bolts/nuts/ fitments are rusted and encrusted....
edh
chrisg said:I guess the bottom line is that because of the age of all of our cars, by default (unless theyve been apart or replaced) all of the bolts/nuts/ fitments are rusted and encrusted....
I'm surprised how rarely I find a seized bolt, or snap one off.... From memory the only problems have been the alternator tensioner - seized solid & needs lots of heat, and one caliper bleed screw.
I think it compares very well with other much more modern cars (apparently the front damper change in my E91 was a pain - everything was seized..I didn't do that one myself [
Mikebarry202
PSH
Pete
